chrisb9341
#1 Posted : Monday, August 3, 2009 5:13:14 PM(UTC)
chrisb9341
I recently ran the dishwasher with very little water pressure. The hot water valve was stuck almost closed due to my screw up. The washer partially filled then did nothing. wouldnt even drain. Keypad lights go on but nothing happens. Is there a reset code i can try once I get the water fixed so pressure is normal?
Thanks.
#2 Posted : Tuesday, August 4, 2009 4:15:33 PM(UTC)
Possible it was overheated. Check the thermal fuse (#4 on the diagram) for continuity. Check the door switches and how they are engaged when the door closed.
- The thermal fuse Part number: AP3115186
