| » Upper wash arm does not spin |
Model Number: GU980SCGB3 Brand: Whirlpool Age: 5 - 10 years
The upper wash arm is not spinning on my diswasher. I took a look and found the cover screws to the filter screen had loosened and the gasket not in place. I reseated gasket and tightened screws and washer worked fine for a couple of weeks.
Now back to same problem with wash arm except gasket is in place this time, so i pulled it down farther. Managed to break the wash impeller when trying to remove it from the motor shaft. I couldn't find anything that looked out of ordinary. The drain check valve seems to work ok. I need some help please. Ads By Google Related Models |
| Display Modes | |
| upper wash arm not cleaning glasses | David Rutherford | Dishwasher Repair | 1 | 01-13-2010 02:12 AM |
| upper wash arms not working, no water | larry compton | Dishwasher Repair | 1 | 09-10-2009 08:52 AM |
| Upper Arm does not spin | acstella | Dishwasher Repair | 11 | 07-03-2009 02:40 PM |
| Upper Spray Arm Doesn't spin | lakeshore | Dishwasher Repair | 4 | 11-04-2008 12:45 PM |
| Washer not pumping at the end of wash but will pump on spin and lite wash. | rathbonr | Washer Repair | 0 | 07-16-2008 11:45 AM |
