I have a drip coming from the bottom right hand side of the door. I replaced the door gasket, it seemed ok for a while, it started happening again. I do not think it is the door gasket causing my problem. I thought maybe the bottom door seal was bad, this is discontinued from GE, I cannot order it. Apparently, this part never goes bad. The bottom of the outer door skin fills up with water and I'm not sure why. When I open the door, the gasket is dry where it touches the door. I believe the water is coming from where the bottom of the tub meets the door. It is spilling over the end of the tub and filling the bottom of the door. I also checked the level of the unit, it wasn't perfectly level, I adjusted it, but the problem still exists. Thanks in advance for any advice.
