| » stays on too long |
Model Number: shu9955uc-14 Brand: Bosch Age: 5 - 10 years
Runs many hours before finally shutting down
Quote:
Running the machine through the diagnostic mode did not provide any usuable information. I will update findings Doug |
Quote:
Thanks for the heads-up. I tested the input current with my Amprobe and found I got the correct value (1.5 to 2 amperes) when the drain pump or the circulator pump were running. When it was time for the heating element to function, I didn't read the normal 11 amperes. I now proved that the water is not heating during the wash cycle. Your were spot-on! My next step to measure the voltage out of the control board, using a voltmeter. I sould measure 120 VAC on the RED wire when it is time for the water to heat during the wash cycle. Getting a correct 120 VAC reading will prove that the relay in the control module is functioning and sending the required voltage to the heating element circuit. Unfortunately, there is also 2 sensors/switches in this loop, so further testing will be required to deterime which of the 3 components is actually defective. No measured voltage will comform a defective control module. I will post updates. Doug |
| Display Modes | |
| Stays Off/in Defrost To Long-ge Eterna Series | reajigsaw413 | Refrigerator & Freezer Repair | 9 | 12-22-2012 09:25 AM |
| GE freezer defrost stays on too long?? | rawaldrip@aol.com | Refrigerator & Freezer Repair | 10 | 03-10-2012 10:15 PM |
| Refrigerator stays on defrost too long. | diamond007 | Refrigerator & Freezer Repair | 1 | 03-31-2011 02:12 AM |
| Stays on in more dry/less dry setting | thepup310 | Dryer Repair | 2 | 04-08-2009 03:47 AM |
| GE Fan stays on | jfgkahaluu | Microwave Repair | 2 | 12-31-2008 11:18 AM |
