So the other day I found that my dishwasher had leaked. After some research I found out that it must be the bottom door gasket. Following the great help posted on this forum at http://forum.appliancepartspros...-d-w-door-leak-help.html I replaced the door gasket and stopped that leak . . . only to find that there was another or possible two. With the access panel removed their is water dripping of the clear tube the goes from the right side of the dishwasher (with some insulation at the right side) to the center under the dishwasher. It looks like the leak is running down the clear tubing from where it comes out of the bottom of the dishwasher on the right side. Any ideas? Also there is a smaller less consequential leak around the soap dispenser . . . I think this leak may get caught before it hits the floor, but is there a gasket there that can be easily replaced?
