Discuss
Dishwasher Won't complete cycle
 in
Dishwasher Repair
The dishwasher doesn't complete the cycle when the time is up. The drain pump was tested and works. The &
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Won't complete cycle
  #1 (permalink)
Old 01-09-2008, 05:01 PM
Rollo Rollo is offline
Junior Member
Rollo is on a distinguished road
Question Dishwasher Won't complete cycle
Model Number: SHU5312   Brand: Bosch   Age: 5 - 10 years
The dishwasher doesn't complete the cycle when the time is up. The drain pump was tested and works. The "Heater Assembly" does not activate (no 11amp+/- drawdown anywhere in the cycle although the element resistance appears in spec.) and I don't believe this is controlled by the control module. Would this prevent the cycle from completing and activating the drain pump? I don't want to replace an expensive part without reasonable cause.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador won't complete cycle mike1086c Dishwasher Repair 2 01-05-2008 06:58 AM
drains before cycle is complete thompsodl Dishwasher Repair 1 12-17-2007 08:26 PM
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 08:20 PM
Bosch dishwasher won't complete cycle brewstmp Dishwasher Repair 5 12-13-2007 08:17 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 01:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
