Discuss
DW not draining/starting
 in
Dishwasher Repair
I just replaced the circuit board on my DW. It was working intermittently after the installation. I check the float
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » DW not draining/starting
  #1 (permalink)
Old 01-09-2008, 01:15 PM
fakhar11 fakhar11 is offline
Junior Member
fakhar11 is on a distinguished road
Default DW not draining/starting
Model Number: MDB5100AWW   Brand: Maytag   Age: 1 - 5 years
I just replaced the circuit board on my DW. It was working intermittently after the installation. I check the float and it had some sticky residue stuck inside. I literally popped float and cleaned it. When I tried to put the float back, it would not stay in its holder. I found out about this palnut that holds the float in place. Now, the DW does not even start. I am suspecting the float in this problem. If I re-install the float with the palnut, do you think everything will be fixed? Plus, the motor on the DW was replaced just a year ago. Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not starting ericeberry Dishwasher Repair 1 01-07-2008 06:51 PM
not draining Belkey Washer Repair 1 12-09-2007 09:15 PM
problem starting self cleaning process tsanford Oven Repair (including Ranges and Cooktops) 0 11-10-2007 10:25 PM
Kenmore dryer sounds like starting, doesn't Lynnarie Dryer Repair 0 10-15-2007 11:56 AM
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
