Discuss
Ike
 in
Dishwasher Repair
I have a Thermador dishwasher TD 5500 that is 17 years old. Some parts are not available from Thermador anymore.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Ike
  #1 (permalink)
Old 01-08-2008, 04:23 PM
Ike Ike is offline
Junior Member
Ike is on a distinguished road
Default Ike
Model Number: TD 5500   Brand: Thermador   Age: More than 10 years
When the wash cycles begin, there are 2 leaks separate leaks coming from the front left inside side of the door, about 6" in from the left. The first is at the beginning of the first wash cycle, it is about 2 ounces and is sudsy; the second is at the beginning of the next wash/water cycle, it is about 6 ounces and is sudsy. The leak is below the Jet-Dry liquid container area. I have looked and felt at the inside of the door (where the door meets the tub) and there seems to be an area of about 5-6 inches where there is no gasket, or else it is pushed under and crushed causing this leak.
What should I do? Should I unscrew the screws on the inside of the door and remove the panel and try and reposition the gasket or will this be a problem reassembling the soap and Jet Dry dispensers? Can I put kitchen and bath 100% silicone at thisd area to stop the leak?
Please, your suggestions.
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
