I am getting some leakage around the water inlet assembly and want to repair it myself. When I look at the blow up parts list it shows Bezel inlet, gasket and inlet assembly I can't tell how the Bezel inlet and the inlet assembly are removed from both sides of the dishwasher wall to replace the gasket if it is leaking. I'm not sure what part is involved with the leak, I expect it is the gasket but I'm not sure how to get the assembly apart. Do I swivel the bezel and does it screw into the inlet assembly for instance, or does it pop off. Can anybody help here? The model # is Kitchenaide KUDS25SHBL1 Thanks
