Discuss
Leaking Kenmore dish-w
 in
Dishwasher Repair
Kenmore 'Ultra' 11, model 665 168 12990 (the '2990' is a 'new' number at Sears, an 'updated number') Broken glass,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking Kenmore dish-w
  #1 (permalink)
Old 02-19-2012, 06:59 PM
Junior Member
Michael J Yeager is on a distinguished road
Default Leaking Kenmore dish-w
Model Number: 665 168 12990   Brand: Kenmore   Age: 5 - 10 years
Broken glass, slight noise while in process but enough to make one look. Removed lower spin-sprayer, and lower enclosed screen. Removed impeller 'cap', by removing hex head, quarter inch nut, with affixed gasket)
Slid impeller cap off, reaching actual impeller, the underside of which has flat, white, 3-eighths, apparent washer purpose, as part of actual impeller. Four 'main screws', apparently hold screened enclosed basket, with bottom screening as well, tightly to the central pump unit on floor of tub. Cleaned entire area, some old pot and pan nuts, some minor rust, glass pieces the apparent cause of noise, no obvious damage to any parts.
Reassembled, now leaks dead center, at motor axle, once refill begins and underneath of course.
It seems that the impeller, seats against a coated spring fixed against the tub housing and when top nut is tightened against impeller 'cap', the white underside washer must press against the coated, three tier compression spring, then making seal? I've looked very closely for any other place for such leakage. So, would it be the impeller washer, or that coated spring at the motor axle, but apparently attached to the tub frame? In other words, what would a guy replace?
Obvious advance thanks for any advice
Ads By Google
Related Models
Kenmore 665110739120 DISHWASHER
Kenmore 665110739130 DISHWASHER
Kenmore 665110739140 DISHWASHER
Kenmore 665110739190 DISHWASHER
Kenmore 66513012K110 UNDERCOUNTER DISHWASHER
Kenmore 66513013K110 UNDERCOUNTER DISHWASHER
Kenmore 66513014K110 UNDERCOUNTER DISHWASHER
Kenmore 66513019K110 UNDERCOUNTER DISHWASHER
Kenmore 66513023K110 DISHWASHER
Kenmore 66513032K110 UNDERCOUNTER DISHWASHER
Kenmore 66513033K110 UNDERCOUNTER DISHWASHER
Kenmore 66513039K110 UNDERCOUNTER DISHWASHER
Kenmore 66513042K110 UNDERCOUNTER DISHWASHER
Kenmore 66513043K110 UNDERCOUNTER DISHWASHER
Kenmore 66513044K110 UNDERCOUNTER DISHWASHER
Kenmore 66513049K110 UNDERCOUNTER DISHWASHER
Kenmore 66513102K900 DISHWASHER
Kenmore 66513102K901 UNDERCOUNTER DISHWASHER
Kenmore 66513102K902 UNDERCOUNTER DISHWASHER
Kenmore 66513103K900 DISHWASHER
Kenmore 66513103K901 UNDERCOUNTER DISHWASHER
Kenmore 66513103K902 UNDERCOUNTER DISHWASHER
Kenmore 66513104K900 DISHWASHER
Kenmore 66513104K901 UNDERCOUNTER DISHWASHER
Kenmore 66513104K902 UNDERCOUNTER DISHWASHER
Kenmore 66513109K900 DISHWASHER
Kenmore 66513109K901 UNDERCOUNTER DISHWASHER
Kenmore 66513109K902 UNDERCOUNTER DISHWASHER
Kenmore 66513112K700 DISHWASHER
Kenmore 66513112K701 DISHWASHER
Kenmore 66513112K702 UNDERCOUNTER DISHWASHER
Kenmore 66513113K700 DISHWASHER
Kenmore 66513113K701 DISHWASHER
Kenmore 66513113K702 UNDERCOUNTER DISHWASHER
Kenmore 66513114K700 DISHWASHER
Kenmore 66513114K701 DISHWASHER
Kenmore 66513114K702 UNDERCOUNTER DISHWASHER
Kenmore 66513119K700 DISHWASHER
Kenmore 66513119K701 DISHWASHER
Kenmore 66513119K702 UNDERCOUNTER DISHWASHER
Kenmore 66513122K700 DISHWASHER
Kenmore 66513122K701 DISHWASHER
Kenmore 66513122K702 DISHWASHER
Kenmore 66513122K703 DISHWASHER
Kenmore 66513123K700 DISHWASHER
Kenmore 66513123K701 DISHWASHER
Kenmore 66513123K702 DISHWASHER
Kenmore 66513123K703 DISHWASHER
Kenmore 66513124K700 DISHWASHER
Kenmore 66513124K701 DISHWASHER
Kenmore 66513124K702 DISHWASHER
Kenmore 66513124K703 DISHWASHER
Kenmore 66513129K700 DISHWASHER
Kenmore 66513129K701 DISHWASHER
Kenmore 66513129K702 DISHWASHER
Kenmore 66513129K703 UNDERCOUNTER DISHWASHER
Kenmore 66513132K700 DISHWASHER
Kenmore 66513132K701 DISHWASHER
Kenmore 66513133K700 DISHWASHER
Kenmore 66513133K701 DISHWASHER
Kenmore 66513139K700 DISHWASHER
Kenmore 66513139K701 DISHWASHER
Kenmore 66513152K700 DISHWASHER
Kenmore 66513152K701 DISHWASHER
Kenmore 66513152K702 DISHWASHER
Kenmore 66513153K700 DISHWASHER
Kenmore 66513153K701 DISHWASHER
Kenmore 66513153K702 DISHWASHER
Kenmore 66513154K700 DISHWASHER
Kenmore 66513154K701 DISHWASHER
Kenmore 66513154K702 DISHWASHER
Kenmore 66513159K700 DISHWASHER
Kenmore 66513159K701 DISHWASHER
Kenmore 66513159K702 DISHWASHER
Kenmore 66513163K700 DISHWASHER
Kenmore 66513163K701 DISHWASHER
Kenmore 66513163K702 DISHWASHER
Kenmore 66513163K703 DISHWASHER
Kenmore 66513169K700 DISHWASHER
Kenmore 66513169K701 DISHWASHER
Kenmore 66513169K702 DISHWASHER
Kenmore 66513169K703 DISHWASHER
Kenmore 66513173K700 DISHWASHER
Kenmore 66513173K701 DISHWASHER
Kenmore 66513173K702 DISHWASHER
Kenmore 66513173K703 DISHWASHER
Kenmore 66513173K704 UNDERCOUNTER DISHWASHER
Kenmore 66513182K800 DISHWASHER
Kenmore 66513182K801 DISHWASHER
Kenmore 66513182K802 DISHWASHER
Kenmore 66513183K800 DISHWASHER
Kenmore 66513183K801 DISHWASHER
Kenmore 66513183K802 DISHWASHER
Kenmore 66513189K800 DISHWASHER
Kenmore 66513189K801 DISHWASHER
Kenmore 66513189K802 DISHWASHER
Kenmore 66513192K900 DISHWASHER
Kenmore 66513192K901 UNDERCOUNTER DISHWASHER
Kenmore 66513192K902 DISHWASHER
Kenmore 66513193K900 DISHWASHER
Kenmore 66513193K901 UNDERCOUNTER DISHWASHER
Kenmore 66513193K902 DISHWASHER
Kenmore 66513194K900 DISHWASHER
Kenmore 66513194K901 UNDERCOUNTER DISHWASHER
Kenmore 66513194K902 DISHWASHER
Kenmore 66513199K900 DISHWASHER
Kenmore 66513199K901 UNDERCOUNTER DISHWASHER
Kenmore 66513199K902 DISHWASHER
Kenmore 66513206K901 UNDERCOUNTER DISHWASHER
Kenmore 66513206K902 DISHWASHER
Kenmore 66513212K901 UNDERCOUNTER DISHWASHER
Kenmore 66513212K902 UNDERCOUNTER DISHWASHER
Kenmore 66513213K900 UNDERCOUNTER DISHWASHER
Kenmore 66513213K901 UNDERCOUNTER DISHWASHER
Kenmore 66513213K902 UNDERCOUNTER DISHWASHER
Kenmore 66513219K901 UNDERCOUNTER DISHWASHER
Kenmore 66513219K902 UNDERCOUNTER DISHWASHER
Kenmore 66513222K600 DISHWASHER
Kenmore 66513222K601 DISHWASHER
Kenmore 66513223K600 DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore DW leaking leakyparts Dishwasher Repair 1 05-11-2010 03:22 PM
kenmore dish stuck in open position mtillman3 Dishwasher Repair 0 01-07-2010 07:02 AM
kenmore dish stuck in open position mtillman3 Dishwasher Repair 1 01-04-2010 08:17 PM
GE dish washer still leaking after installing impeller akhan Dishwasher Repair 2 11-15-2008 07:48 AM
Kenmore ultra wash dish washer tbase1 Dryer Repair 1 10-10-2007 02:53 PM
