Discuss
Dishwasher won't do ANYTHING!
 in
Dishwasher Repair
I have a Kitchen Aid DW, Model #KUDS01DJSS0. The unit does not function at all. The light on the "
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher won't do ANYTHING!
  #1 (permalink)
Old 01-07-2008, 11:23 PM
gabe380 gabe380 is offline
Junior Member
gabe380 is on a distinguished road
Default Dishwasher won't do ANYTHING!
Model Number: KUDS01DJSS0   Brand: Kitchen Aid   Age: 5 - 10 years
I have a Kitchen Aid DW, Model #KUDS01DJSS0. The unit does not function at all. The light on the "rinse only" button is blinking, and there are 2 dashes in the led screen. Otherwise, nothing works. No buttons function at all. Is this a "control panel" issue, or a "circuit board" issue? Or some other issue altogether??
Thanks,
Gabe
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-08-2008, 05:32 PM
FrustratedButDetermined FrustratedButDetermined is offline
Junior Member
FrustratedButDetermined is on a distinguished road
Default Sounds Familiar
(This is copied from another thread on the same subject.)
My KUD0S1 is doing exactly the same thing.
I replaced the control/timer circuit board to no avail. I'm guessing that replacing it won't help your problem either.
I jumpered each of the microswitches in turn (including the door latch). When I disconnected the vent thermistor, and cycled the power, it behaved differently, so I replaced the vent assembly (which contains a new thermistor). Still no joy.
I disassembled the 'soil sensor'/pressure switch. I found the (internal) contacts were badly corroded. So I cleaned it all up, verified it worked (using an ohmmeter). Yet no change in the behaviour.
I hadn't considered the touch panel (the 'delay' button is a little soft) as a possibility, otherwise I'm running out of ideas.
Any thoughts anyone?
  #3 (permalink)
Old 01-09-2008, 10:44 AM
catholic catholic is offline
Junior Member
catholic is on a distinguished road
Default
I've had this same problem corrected. What I had to do was replace the control that is next to the door latch on the dishwasher. However this was a recurring problem with this specific year of the model. I had to continually replace the control to get the dishwasher working again. Mine wasn't a Kitchenaid though.
I"d suggest following any troubleshooting material that came with your dishwasher, otherwise try to have it serviced.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
