Discuss
Bosch SHU4022 fill value not closing properly
 in
Dishwasher Repair
Our Bosch SHU4022UC/U06 dishwasher problem is that water continues to fill during a segment of the cycle that fill
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch SHU4022 fill value not closing properly
  #1 (permalink)
Old 07-24-2009, 05:40 PM
rainforest rainforest is offline
Junior Member
rainforest is on a distinguished road
Default Bosch SHU4022 fill value not closing properly
Model Number: SHU4022UC/U06   Brand: Bosch   Age: More than 10 years
Our Bosch SHU4022UC/U06 dishwasher problem is that water continues to fill during a segment of the cycle that fill should be off. We have compared function to the timer diagram for this model, so we know this is true.
When this filling continues, the drain will turn on periodically during a circulation segment presumably because there is too much water in unit. In other words, we have never had a leak due to this problem, its just that a wash cycle uses way too much water (fill may be on up to 40 minutes during 90 minute cycle.)
While the fill is running when it is supposed to be off, if we manually shut off the water and then turn manual value back on, the fill typically will then be off. It's as if the fill valve cannot shutoff if it has water pressure on inlet side. (Our house water pressure is low for norm). However, we have also noticed that the fill shutoff predominately fails when circulation is occuring. For those segments of timer when fill is the only event happening, the fill can shut off at end of segment. So this implies maybe pressure on outlet side affects it? Or perhaps voltage applied to water value is affected by unit powering circulation at same time?
We have checked the resistance on the water value, it is 980 ohms. That implies the water value is OK (according to Troubleshooting available on this site, should be ~1000 ohms). However the behavior sure implies that the water value is the problem.
We have checked, there is no debris in base affecting float switch.
Should we just replace the water value? Or could this have something to do with the float switch, timer, or voltage applied to water value leads? Are there any further troubleshooting tips to try? I could not find a repair manual for this older model.
Related Models
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
  #2 (permalink)
Old 08-15-2009, 04:32 PM
Junior Member
Default solution
No one answered my question, so we just purchased a water fill valve (part #19 shown in the base diagram for this model), and this solved the problem. Hurrah!
Once we had the old valve removed, we noticed it was possible to blow a small amount of air through the closed valve. With the new valve, this was not possible.
The repair was easy to do, just remove the front kickplate panel, disconnect water supply, remove a couple screws, wiggle the valve out of its slot, change the electrical and back water connection, and then reverse all that to put it back together.
Dishwasher now runs great, after a $35 part and 15 minutes of repair.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven door not closing properly irasend Oven Repair (including Ranges and Cooktops) 1 01-13-2010 03:42 PM
Ice chute not closing properly Scottie1 Refrigerator & Freezer Repair 1 07-04-2009 09:44 AM
Bosch DW does not fill or drain properly carol kittelson Dishwasher Repair 5 10-02-2008 11:10 AM
Bosch DW does not fill or drain properly carol kittelson Dishwasher Repair 1 09-26-2008 02:31 PM
Refridgerator door not closing properly glcarpe Refrigerator & Freezer Repair 1 09-18-2007 07:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
