| » Bosch diswasher runs but doesn't drain |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: SHK46L05UC Brand: Bosch Age: 1 - 5 years
The dishwasher runs but doesn't drain. I have to siphon the water out of the tub after it finishes it complete wash cycle. The water in the tub is then still dirty, so I have to complete the job with two siphon and rinse cycles.
One more step I have to take every so often is to remove the water from the pan under the tub otherwise the washer won't allow any water in. Any suggestions? Is it a sensor problem, or is there a separate drain pump and that's faulty? One more problem is that Bosch won't release their circuit diagrams to me, so I'm working in the dark. |
The model number you provided is incorrect.
Verify and repost the model number, please. Gene.
__________________
Professional appliance repair services in Orange County, California. |
Thanks, Gene, for your response. You're right. The model number I quoted is wrong. The right one is SHX46L05UC.
Possible a foreign objects inside the drain hose or the drain pump.
Also possible water leak under the dishwasher. Remove the toe kicks and inspect for the water leaks and/or water marks. Disconnect the drain hose from the air gap, put it in a bucket and run the drain cycle. Post your findings. Gene.
__________________
Hi Gene,
Thanks for your suggestions. There are no water leaks on the floor. The pan under the tub collects water, however, so after about three rinse and siphon-drain cycles I have to remove some of it otherwise the tub won't fill. There is no air gap. The drain hose runs right into the waste disposal unit. I disconnected the hose at that point and directed it into a bucket. No water came out when the washer ran. I also blew into the end of the drain hose and could hear bubbles in the water in the tub, so I guess there's no blockage. That covers your questions. What next? Sincerely, Michael Burrows |
| Display Modes | |
| Bosch Dishwasher won't drain | reisman | Dishwasher Repair | 4 | 12-27-2007 02:50 AM |
| Bosch drain pumps does not turn off? | dallymemally | Dishwasher Repair | 2 | 10-26-2007 04:09 PM |
| Bosch drain pump replacement | Tom4852 | Dishwasher Repair | 3 | 10-03-2007 05:04 PM |
| Bosch Dishwasher Won't Drain | jshoe01 | Dishwasher Repair | 2 | 09-06-2007 10:27 AM |
| Replacing Drain Hose on Bosch Dishwasher | Lorenzo | Dishwasher Repair | 2 | 08-07-2007 06:24 AM |
