Discuss
Bosch diswasher runs but doesn't drain
 in
Dishwasher Repair
The dishwasher runs but doesn't drain. I have to siphon the water out of the tub after it finishes
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch diswasher runs but doesn't drain
  #1 (permalink)
Old 01-07-2008, 05:55 PM
michaelleonardburrows@yah michaelleonardburrows@yah is offline
Junior Member
michaelleonardburrows@yah is on a distinguished road
Default Bosch diswasher runs but doesn't drain
Model Number: SHK46L05UC   Brand: Bosch   Age: 1 - 5 years
The dishwasher runs but doesn't drain. I have to siphon the water out of the tub after it finishes it complete wash cycle. The water in the tub is then still dirty, so I have to complete the job with two siphon and rinse cycles.
One more step I have to take every so often is to remove the water from the pan under the tub otherwise the washer won't allow any water in.
Any suggestions? Is it a sensor problem, or is there a separate drain pump and that's faulty?
One more problem is that Bosch won't release their circuit diagrams to me, so I'm working in the dark.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-08-2008, 05:33 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The model number you provided is incorrect.
Verify and repost the model number, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-09-2008, 10:34 AM
Junior Member
Default
Thanks, Gene, for your response. You're right. The model number I quoted is wrong. The right one is SHX46L05UC.
  #4 (permalink)
Old 01-09-2008, 12:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Possible a foreign objects inside the drain hose or the drain pump.
Also possible water leak under the dishwasher.
Remove the toe kicks and inspect for the water leaks and/or water marks.
Disconnect the drain hose from the air gap, put it in a bucket and run the drain cycle.
Post your findings.
__________________
  #5 (permalink)
Old 01-09-2008, 09:46 PM
Junior Member
Default Answer for Gene re Bosch dishwasher drain problem
Hi Gene,
Thanks for your suggestions.
There are no water leaks on the floor. The pan under the tub collects water, however, so after about three rinse and siphon-drain cycles I have to remove some of it otherwise the tub won't fill.
There is no air gap. The drain hose runs right into the waste disposal unit. I disconnected the hose at that point and directed it into a bucket. No water came out when the washer ran.
I also blew into the end of the drain hose and could hear bubbles in the water in the tub, so I guess there's no blockage.
That covers your questions. What next?
Sincerely,
Michael Burrows
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Bosch Dishwasher won't drain reisman Dishwasher Repair 4 12-27-2007 03:50 AM
Bosch drain pumps does not turn off? dallymemally Dishwasher Repair 2 10-26-2007 05:09 PM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
Bosch Dishwasher Won't Drain jshoe01 Dishwasher Repair 2 09-06-2007 11:27 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
