Bosch Dishwasher doesn't work, I replaced the Selection Switch but it still doesn't work. When I pull the handle to open the door, the light on the Seletion Switch goes on but when I close the door, the Selection Switch goes off. The Switch that is located at the door handle turns the Seletion Switch on when it is depressed (opened door) but it turns the light off when it is in the release postion (closed door). This is strange since the Switch should turn on the Seletion Switch when the door is closed not opened????
Thanks,
Nikos K.
