| » DW new motor wont cycle long enough |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 665.17799992 Brand: Kenmore Age: 5 - 10 years
I just replaced the motor, it had a broken shaft. Now it works but wont stay in drain or wash cycle long enough. Only about 15 seconds then shuts off.
Any ideas? |
What exactly did you replace?
The pump and motor assembly, just the motor or the motor and the impeller & seal kit? Gene.
__________________
Professional appliance repair services in Orange County, California. |
Having problems with my Kenmore dishwasher. It seems to only want to run for 15 seconds or so on any cycle I choose. It will fill and heat but will not rinse or drain properly. It seems the new motor overheats and shuts down. I have replaced every part of the pump assembly. Please help before my hands become too wrinkled from washing manually.
I personally haven't had the same situation, but I do know that there is a thermal cut out on all motors which will disable the motor if the copper windings get too hot. It is used to prevent a fire from occurring. When the copper windings cool down, the motor is operable again. This possibility may not be likely for these two cases since you said you just bought the motor. However if it is an older motor/service motor, it may be the case. But still it's rare. If it seems the only option is this, I'd call the manufacturer's service department to have it checked out.
| Display Modes | |
| Takes tpo long to dry.. | SLEEPING_GIANTRT | Dryer Repair | 3 | 12-23-2007 12:25 PM |
| Spin cycle either 'weak' , motor runs & tub doesn't turn or ... | sfw1960 | Washer Repair | 10 | 11-26-2007 12:00 PM |
| Dishwasher won't go thru cycle but motor keeps running | jeanniet@rogers.com | Dishwasher Repair | 0 | 11-17-2007 02:03 PM |
| Dryer wont stop cycle automatically runs continously | MrSchlimmer | Dryer Repair | 1 | 10-31-2007 03:43 AM |
| long cycle on washer | burks | Washer Repair | 1 | 09-21-2007 02:57 AM |
