| » Kenmore dishwasher only starts after disassembly |
Model Number: 665.16372300 Brand: Kenmore Age: 5 - 10 years
Recently my Kenmore dishwasher has become increasingly troublesome. After closing the door, the dishwasher will not start by pressing the "start" button. If I press the "Drain/Cancel" button, it will drain. I can select a wash mode (with the corresponding LED lighting up), I can select a delay start, but pressing "start" does nothing. I took the front cover off and disconnected everything from the main control board. Noticing two bad 470 micro-F capacitors (but not having spares on hand), I put everything back together and turned the power back on. The "Start" button worked properly after that. A few days later it stopped working again, so again I dismantled it, changed nothing, reassembled it and the "Start" button worked again. This process has been going on for nearly a month. A few days ago I bought two 470 micro-F capacitors and replaced the two distended ones. Same result, the start button works and then it doesn't. At this point, I don't know if I should buy a new control board, or a new faceplate (reasoning that the physical button/micro controller is going bad). I found the board to be part number AP3775964 but I can't find the white faceplate. Suggestions are welcome. Which part is likely going bad? Ads By Google Related Models |
Most likely the problem is a bad control panel ribbon cable. It's not repairable and comes as a part of the control panel. So the solution is to replace the control panel.
- The white control panel Part number: AP4108545 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks Gene! I ordered the front panel and everything worked great for a week. Then the thermal fuse blew (DMM registers no continuity and shorting it results in the dishwasher starting), seeing as this is the first time it's blown, I believe they're unrelated and I just ordered a fuse.
Thanks again for the advice and the part number! |
__________________
You are welcome. I'm glad it's up and running.
__________________
| Display Modes | |
| dishwasher door disassembly | judicliff | Dishwasher Repair | 0 | 09-03-2011 01:52 PM |
| whirlpool dishwasher disassembly | debbie.reed | Dishwasher Repair | 1 | 01-31-2011 01:54 PM |
| Whirlpool dishwasher disassembly | klc4570 | Dishwasher Repair | 2 | 01-30-2011 08:57 PM |
| Need help with disassembly of GE dishwasher | Phydeauxman | Dishwasher Repair | 0 | 07-17-2010 04:24 AM |
| Kenmore canister vacuum disassembly | PeteS | General Talk | 0 | 01-02-2009 07:13 PM |
