chevy3kf
#1 Posted : Monday, February 13, 2012 5:01:48 AM(UTC)
chevy3kf
Dishwasher will not start. Light will not light up when you select the wash cycle. Dishwasher does has power to it. Checked connections to all electronics on the control panel. Any ideas???
#2 Posted : Wednesday, February 15, 2012 3:49:30 AM(UTC)
Replacement parts for Maytag MDB7601AWQ DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
See the attachment for the tech sheet
If you are sure that the control board is getting power and both door latch switches close then try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If that does nothing then you will have to check the the control panel/keyboard with a meter (see the tech sheet) as it could be either the control panel or the control board.
If it checks out OK then I would replace the control board.
Still a bit of a crap shoot but your odds are better.
File Attachment(s):
MDB7601.pdf (120kb) downloaded 16 time(s).
mjazcko
#3 Posted : Thursday, February 23, 2012 6:31:23 PM(UTC)
mjazcko
With an ohm meter in hand, how do you determine if the control panel or control board is bad?
#4 Posted : Saturday, February 25, 2012 2:34:15 AM(UTC)
See the attachment.
Your model must be the same.
Subzero 650 Control Panel (Refrigerator & Freezer Repair)
by kbf99 2/14/2024 5:06:04 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dispenser control panel is dead (Refrigerator & Freezer Repair)
by Expat 1/21/2023 1:56:42 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Whirlpool WRF555SDHV refrigerator dispenser control panel (Refrigerator & Freezer Repair)
by janinePR 12/8/2022 2:17:23 PM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Maytag MHWE300VW00 Control Panel shuts off, then on, then off... (Washer Repair)
by ab2112 8/1/2022 10:00:14 AM(UTC)
GE frig Control Panel replacment procedure (Refrigerator & Freezer Repair)
by whkendri 4/27/2022 6:41:50 AM(UTC)
