| » Upper spray arm not effective |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: shu3036uc/uc12 Brand: Bosch Age: 5 - 10 years
Water pressure does not appear strong enough to power the upper spray arm. I pulled the unit out and the water valve assembly had some black rubber gasket bits in front of the pink screen, and I'm hoping that's the problem. (not sure what the function of the water valve is.)
Or should I check the impeller on the circulation pump before re installing the machine? Is a pump rebuild kit effective or do I need a new one? |
Why you think the upper spray arm is not spinning properly?
What was the original problem? Gene.
__________________
Professional appliance repair services in Orange County, California. |
If you just noticed that the upper spray arm is not turning, the problem is probably that you have calcium buildup in the spray arm's holes that let out the water. Without the water moving out of the holes the spray arms won't spin properly. If this is the problem, use a pin to poke through the calcium.
| Display Modes | |
| Upper spray arm does not rotate | btd | Dishwasher Repair | 2 | 01-04-2008 08:31 PM |
| Removing the upper agitator bolt | pcntexas | Washer Repair | 3 | 12-10-2007 07:21 PM |
| Upper rack disassembly | flsunshine | Dishwasher Repair | 2 | 12-07-2007 06:24 AM |
| upper oven not working | drembo | Oven Repair (including Ranges and Cooktops) | 0 | 11-03-2007 09:13 AM |
| upper and lower burners not consistent | artkat | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2007 02:29 PM |
