Discuss
Upper spray arm not effective
 in
Dishwasher Repair
Water pressure does not appear strong enough to power the upper spray arm. I pulled the unit out and the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Upper spray arm not effective
  #1 (permalink)
Old 01-06-2008, 09:47 PM
aak11 aak11 is offline
Junior Member
aak11 is on a distinguished road
Default Upper spray arm not effective
Model Number: shu3036uc/uc12   Brand: Bosch   Age: 5 - 10 years
Water pressure does not appear strong enough to power the upper spray arm. I pulled the unit out and the water valve assembly had some black rubber gasket bits in front of the pink screen, and I'm hoping that's the problem. (not sure what the function of the water valve is.)
Or should I check the impeller on the circulation pump before re installing the machine? Is a pump rebuild kit effective or do I need a new one?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 04:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Why you think the upper spray arm is not spinning properly?
What was the original problem?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-10-2008, 11:08 AM
catholic catholic is offline
Junior Member
catholic is on a distinguished road
Default
If you just noticed that the upper spray arm is not turning, the problem is probably that you have calcium buildup in the spray arm's holes that let out the water. Without the water moving out of the holes the spray arms won't spin properly. If this is the problem, use a pin to poke through the calcium.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upper spray arm does not rotate btd Dishwasher Repair 2 01-04-2008 09:31 PM
Removing the upper agitator bolt pcntexas Washer Repair 3 12-10-2007 08:21 PM
Upper rack disassembly flsunshine Dishwasher Repair 2 12-07-2007 07:24 AM
upper oven not working drembo Oven Repair (including Ranges and Cooktops) 0 11-03-2007 10:13 AM
upper and lower burners not consistent artkat Oven Repair (including Ranges and Cooktops) 0 09-28-2007 03:29 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
