Discuss
Dishwasher Problems
 in
Dishwasher Repair
When turning the dishwasher on, it seems to fill with water, but not completely full and is leaking out the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Problems
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-08-2007, 01:11 PM
jcuster jcuster is offline
Junior Member
jcuster is on a distinguished road
Default Dishwasher Problems
Model Number: FDB989GFC2   Brand: Frigidaire   Age: 5 - 10 years
When turning the dishwasher on, it seems to fill with water, but not completely full and is leaking out the drain hose the whole time. I am wondering what the problem is... the water valve, the motor pump, or drain pump. The drain seems to make noise, but when you cancel it drains all the water. I tried to turn the motor and it turns. When it begins to clean it doesn't pump the water to the top. I am thinking it's the motor pump, but maybe because there is never enough water in the tub it won't run. Anyone have any suggestions ? Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-08-2007, 05:08 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
The water level should be just below the heating element.
Check your drain hose to make sure at some point it is higher then the water level in the tube.
__________________
  #3 (permalink)
Old 08-08-2007, 09:54 PM
Junior Member
Default
I don't beleive it is.. how can I check the drain hose ? I hear the water draining all the time and when I open it, it's pretty empty.. If there is not enough water will the pump still push water to the top rack ? Thanks for the help,,,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/freezer problems imthewraith Refrigerator & Freezer Repair 3 09-17-2007 02:28 PM
Dryer Problems rr454 Dryer Repair 4 08-09-2007 10:25 PM
Drain Problems mpj680 Dishwasher Repair 6 08-01-2007 08:58 PM
Power Problems With Dryer NESSDIST Dryer Repair 0 07-29-2007 01:36 PM
evaporator fan problems csteven Refrigerator & Freezer Repair 1 07-25-2007 02:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
