My Kenmore Elite dishwasher does not start the wash cycle in anymode. The lights and button all light upand appear to be working when selected. The problem is when you push start the timer display has two red horizontalline "--". Normally theselines would rotate in a circle for a few seconds and then start the selectedcycle. I have removed the front panel and checked the relay voltageon the latching handle and appears to work fine once closed. Looking for suggestions on what the two horizontallines indicated or what I can check next to determine what is causing theproblem. Mac
