Discuss
Dishwasher Pump Replacement/Cleanout
 in
Dishwasher Repair
When the main drain pump in my GE dishwasher turns on, it sounds fine for roughly 5 seconds. It subsequently
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Pump Replacement/Cleanout
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-05-2008, 10:07 AM
Ed De Meter Ed De Meter is offline
Junior Member
Ed De Meter is on a distinguished road
Default Dishwasher Pump Replacement/Cleanout
Model Number: GLD5500L00C   Brand: GE   Age: 1 - 5 years
When the main drain pump in my GE dishwasher turns on, it sounds fine for roughly 5 seconds. It subsequently develops a low rumbling-grinding noise as if there is debris impeding the pump impeller. Is it possible to detach the motor from the pump in order to allow it to be cleaned or must the entire motor-pump assembly be replaced?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 06:04 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You talking about the main circulation pump that operates the spray arms, or the drain pump?? if main pump, pull out and remove plastic screen, left hand thread, and remove objects.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dishwasher upper rack roller replacement Fred Krueger Dishwasher Repair 2 01-10-2008 10:14 AM
Whirlpool pump replacement kroznest Dishwasher Repair 4 12-05-2007 08:21 AM
pump/motor replacement willbill Dishwasher Repair 1 12-04-2007 10:01 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 12:22 PM
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 05:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
