figures. extended warranty just ended. i've done some troubleshooting. previously i noted lower arm moving, middle and upper arm not. tried to remove and unblock middle arm. water seems to come from proper place--middle rear and water seems to come out just not turning. gritty residue on top rack--then last cycle--opened door and water overflowed. pulled out drawer and lower arm. basket did not seem overly full or grimey. water still did not drain once arm out. overflow valve seems to move freely.
