Discuss
Spray arm will not turn
 in
Dishwasher Repair
The spray arm on the KDC 17 does not turn. It seems to have plenty of pressure, I got soaked
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Spray arm will not turn
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-04-2008, 02:23 PM
fletch0491 fletch0491 is offline
Junior Member
fletch0491 is on a distinguished road
Default Spray arm will not turn
Model Number: KDC 17   Brand: Kitchen Aid   Age: More than 10 years
The spray arm on the KDC 17 does not turn. It seems to have plenty of pressure, I got soaked operating it with the door open, but the spray arms do not move. Could they be so old, 35 years, that they need replacing? Does the platform they sit on need re;lacing? How do I determine what the problem is?
Thanks for any help
Fletch
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-05-2008, 03:55 PM
Junior Member
Default Dishwasher Spray arms
I've figured out the dishwasher doesn't have enough water to move the spray arms. When I pour more water in it works fine. The water inlet valve is letting some water in and the continuity test says it is OK. Does the KDC17 have a float valve? Any ideas why a dishwasher won't fill all the way?
Help again
Fletch
  #3 (permalink)
Old 01-05-2008, 06:49 PM
kenson kenson is offline
Junior Member
kenson is on a distinguished road
Default
Check to see if water is going out the drain. If so then the drain valve is suspect. That is what I found on mine.
  #4 (permalink)
Old 01-06-2008, 03:26 PM
Junior Member
Default
Thanks for the help. It worked fine just now so I'm going to leave it alone for the present.
Fletch
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher wont spray drvon Dishwasher Repair 0 11-09-2007 10:17 AM
Dishwasher top spray arm r28shultz Dishwasher Repair 0 10-07-2007 11:48 AM
Install spray arm rshaffer Dishwasher Repair 2 09-20-2007 03:00 PM
lower spray arm jiml Dishwasher Repair 1 09-10-2007 08:38 AM
Spray arm romeroom Dishwasher Repair 2 09-08-2007 12:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
