I replaced the pump motor assembly yesterday.The unit washes fine and no longer sounds like a 747 upon take-off.However, the unit will not drain after completing a cycle.The cancel/drain button will drain the water so I assume the drain pump works.I checked the air gap for obstructions.Any other ideas out there?Thanks.
