Discuss
bosch dishwasher drain motor runs with door open
 in
Dishwasher Repair
My bosch shu9956 dishwasher drain motor runs as soon as it is turned on (even before the door is closed).
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher drain motor runs with door open
  #1 (permalink)
Old 01-18-2012, 02:21 PM
Junior Member
kilroy is on a distinguished road
Default bosch dishwasher drain motor runs with door open
Model Number: bosch shu 9956   Brand: Bosch   Age: 5 - 10 years
My bosch shu9956 dishwasher drain motor runs as soon as it is turned on (even before the door is closed). I tried to run a test cycle, but that didn't work. I checked the floats and they are not activated, although there is a small amount of water in the bottom pan. The dishwasher was level when all this started. I don't know what to check next... any suggestions?
Ads By Google
Related Models
Amana BP22A2E Ref - Bottom Mounts
Amana BP22A2L Ref - Bottom Mounts
Amana BP22AW Ref - Bottom Mounts
Whirlpool BPAC0500AS0
Whirlpool BPAC0500AS1
Whirlpool BPAC0500AS2
Whirlpool BPAC0500AS3
Whirlpool BPAC0500FS0
Whirlpool BPAC0700AS0
Whirlpool BPAC0700AS1
Whirlpool BPAC0700FS0
Whirlpool BPAC0830AS1
Whirlpool BPAC0830AS2
Whirlpool BPAC1000AS0
Whirlpool BPAC1000AS2
Whirlpool BPAC1200AS0
Whirlpool BPAC1200AS2
Whirlpool BPAC1200FS0
Whirlpool BPAC1230AS0
Whirlpool BPAC1230AS2
Whirlpool BPAC1400BS0
Whirlpool BPAC1800AS0
Whirlpool BPAC1800BS0
Whirlpool BPAC1800BS1
Whirlpool BPAC1800BS2
Whirlpool BPAC1800FS0
Whirlpool BPAC1830AS1
Whirlpool BPAC1830AS2
Whirlpool BPAC2400AS0
Whirlpool BPAC2400BS0
Whirlpool BPAC2400BS2
Whirlpool BPAC2400FS0
Whirlpool BPAC2530ES0
Whirlpool BPDH2500AS0
Whirlpool BPDH2500AS1
Whirlpool BPDH2500AS2
Whirlpool BPDH2500FS0
Whirlpool BPDH4000AS1
Whirlpool BPDH4000AS2
Whirlpool BPDH4000AS3
Whirlpool BPDH4000FS0
Whirlpool BPDH5000BS1
Whirlpool BPDH5000BS2
Whirlpool BPDH5000FS0
Maytag BPNS24H9  Ref - SXS/I&W
Maytag BPNS24H9-A  Ref - SXS/I&W
Maytag BPNS24H9A  Ref - SXS/I&W
Maytag BPNS24H9H  Ref - SXS/I&W
Amana BQ20RB Ref - Bottom Mounts
Amana BQ20RBG Ref - Bottom Mounts
Amana BQ20RBL Ref - Bottom Mounts
Amana BQ20RBW Ref - Bottom Mounts
Amana BR-20H Ref - Bottom Mounts
Amana BR14 Misc / Accessory
Amana BR14L Misc / Accessory
Amana BR16E Ref - Bottom Mounts
Amana BR16LE Ref - Bottom Mounts
Amana BR18V1C Ref - Bottom Mounts
Amana BR18V1E Ref - Bottom Mounts
Amana BR18V1S Ref - Bottom Mounts
Amana BR18V1W Ref - Bottom Mounts
Amana BR18V2C Ref - Bottom Mounts
Amana BR18V2E Ref - Bottom Mounts
Amana BR18V2S Ref - Bottom Mounts
Amana BR18V2W Ref - Bottom Mounts
Amana BR18VC Ref - Bottom Mounts
Amana BR18VE Ref - Bottom Mounts
Amana BR18VL Ref - Bottom Mounts
Amana BR18VSE Ref - Bottom Mounts
Amana BR18VW Ref - Bottom Mounts
Amana BR20J Ref - Bottom Mounts
Amana BR20K Ref - Bottom Mounts
Amana BR20M Ref - Bottom Mounts
Amana BR20N Ref - Bottom Mounts
Amana BR20QBL Ref - Bottom Mounts
Amana BR20QBW Ref - Bottom Mounts
Amana BR22S6E Ref - Bottom Mounts
Amana BR22S6L Ref - Bottom Mounts
Amana BR22S6W Ref - Bottom Mounts
Amana BR22TE Ref - Bottom Mounts
Amana BR22TL Ref - Bottom Mounts
Amana BR22TW Ref - Bottom Mounts
Amana BR22V1C Ref - Bottom Mounts
Amana BR22V1E Ref - Bottom Mounts
Amana BR22V1W Ref - Bottom Mounts
Amana BR22VC Ref - Bottom Mounts
Amana BR22VE Ref - Bottom Mounts
Amana BR22VL Ref - Bottom Mounts
Amana BR22VW Ref - Bottom Mounts
  #2 (permalink)
Old 01-20-2012, 01:10 PM
Junior Member
jawshoeaw is on a distinguished road
Default similar problem
I had the same but my drain pump was not draining. Based on a tip from another poster, I opened the little cover over the pump impeller (just pull out filter and screen and unscrew one little torx head screw) and gave it a whirl. Suddenly everything worked again! Very strange how spinning the impeller allowed it to work again but not only did it drain but the motor stopped running with the door open.
Regardless, the pump was now very loud, although it seemed to be working. However, we noticed that the dishes were not getting very clean. Since it was still under warranty I had repairman come out and he replaced the pump. Washer is once again very quiet, haven't ran dirty dishes through it to test cleaning ability.
I took apart the suspect pump and noticed foul smelling debris and water inside the plastic housing where the magnet of the pump spins. Don't know if this is normal or not - maybe the buzzing was just the motor out of balance or vibration from debris? O-Rings appeared OK but not sure what they are supposed to look like. I cleaned it out and will keep it just in case.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Stuck in Drain Cycle; even with door open toungetwster Dishwasher Repair 2 04-21-2012 04:48 AM
Bosch no water comes in drain motor runs TrishG Dishwasher Repair 2 01-03-2012 02:34 PM
door forced open, now door wont lock, drain runs steady scot123 Washer Repair 1 12-20-2011 05:59 PM
Wax Motor Runs like a champ - still no detergent door open during wash cycle MikeG2 Dishwasher Repair 1 08-27-2011 05:35 PM
Bosch SHU5306 drain motor runs, never fills RA3Goat Dishwasher Repair 0 01-12-2011 06:58 PM
