Hey, i had been looking around and read a few topics about this game issue. Although im not sure my model number at this moment i did find http://content.searspart.../PLDM/E2103267-00001.png to match my dishwasher completely. (Possibly GSD2800S45) After coming downstairs to a floor full of water and bubbles i decided to hit the internets. I Removed the inlet sump cover (#506 on the break down diagram) and the cap sump (#508 on the break down diagram) and found some objects which i have removed(broken plastic utensils and some weird wood peice). It seems to still have water in it, how far am i reaching down here? Even after removing the objects the grinding still exists. I find the grinding noise is the worst when water is coming in and going out but the noise still exists while the machine is running its regular cycle. Note: This unit is probably 5-10 years old. Thanks for any help in this matter! -Zero
