| » GE Dishwasher - Standing water (abt an inch or more) left after draining. |
Model Number: GSD5500G01BB Brand: GE Age: 5 - 10 years
GE Dishwasher GSD5500G01BB Standing water (abt an inch or more) left after draining. I cleaned the filter. It appears to drain fine just not all the way. I can see the water being pumped out to the drain pipe. When I put it in F1 Test Mode and run it through the cycle it will drain all the way. Ideas?
Replacement parts for General Electric GSD5500G01BB Dishwasher | AppliancePartsPros.com Probably drains better in test mode just because the drain time is longer. Youir unnit has a piston & nut (see 564 in Section 1)
__________________
Replacement parts for General Electric GSD5500G01BB Dishwasher | AppliancePartsPros.com Probably drains better in test mode just because the drain time is longer. Your unit has a piston & nut (see 564 in Section 1). This is a common cause of drain problems. If it does not seal properly during a drain cycle some water is directed back into the tub instead of out the drain. It is under the screen cover at the back of the tub and it unscrews. Remove and check it.
__________________
| Display Modes | |
| dishwasher leaves abount an inch of water in the bottom | robbob41 | Dishwasher Repair | 1 | 12-11-2011 07:56 AM |
| dishwasher standing water | kschmeck | Dishwasher Repair | 1 | 05-29-2011 04:29 AM |
| Standing water on bottom of dishwasher | Betsy Mackey | Dishwasher Repair | 2 | 02-24-2011 08:01 AM |
| Whirlpool Dishwasher Quit/Left Water Standing | lance_kidd | Dishwasher Repair | 3 | 09-29-2010 11:54 PM |
| Bosch Dishwasher - Standing water from disposal, drains fine normally | lambo17 | Dishwasher Repair | 0 | 10-01-2009 10:57 AM |
