Discuss
Upper spray arm does not rotate
 in
Dishwasher Repair
After replacing upper spray arm assembly arm still does not rotate. Should I now rebuild pump?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Upper spray arm does not rotate
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-04-2008, 10:24 AM
btd btd is offline
Junior Member
btd is on a distinguished road
Default Upper spray arm does not rotate
Model Number: KUDS23HBO   Brand: Kitchen Aid   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-04-2008, 05:41 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Is it enough water to create sufficient pressure in the wash system?
Is the delivery tube for the upper spray arm installed properly?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-04-2008, 08:31 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
is lower spray arm rotating normaly? . often dishes are not beeing rinsed off before being put in d/w, sump screen can be blocked up with food particles preventing normal water pressure from entering tub to spray arms
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing the upper agitator bolt pcntexas Washer Repair 3 12-10-2007 07:21 PM
Upper rack disassembly flsunshine Dishwasher Repair 2 12-07-2007 06:24 AM
upper oven not working drembo Oven Repair (including Ranges and Cooktops) 0 11-03-2007 09:13 AM
Rotator arm won't, rotate that is. dragonlady Dishwasher Repair 1 09-01-2007 01:28 PM
fan does not rotate when turned on so no cold air comes out just alot of noise SKEET21 Heating, Ventilation, and Air Conditioning (HVAC) 1 08-03-2007 10:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
