The door on my better than ten year old Whirlpool dishwasher is still leaking at each of the bottom corners after replacing a visibly damaged tub/door seal, a partially occluded drain hose and a cracked chop & drain impeller. Following the replacement of the drain hose ad impeller kit, the dishwasher is draining noticeably better, however, it still leaks during the end of the wash cycle, just prior to the start of the rinse cycle. I’ve also noticed that, before the rinse cycle, the water level is over the top of the heater element. I’ve check and repositioned the new door gasket twice. The pump housings and free of cracks and all rubber gaskets have been inspected and replaced as required. I’ve got $75 into this thing and am wondering if I’m missing anything before I test the structural integrity of the tub and door handle latch with a few automotive airbag modules in the back yard.
