mopar4u
#1 Posted : Saturday, January 7, 2012 12:24:22 PM(UTC)
mopar4u
Hello
I have a kenmore dishwasher model #5871651590. I'm trying to determine if my water valve assembly is the problem or not and wondering if you could give advice before I make a part purchase. Basically I'm not getting any water into the tub. All i get is a humming noise. The noise is the black electro magnetic thing on the valve assembly. I verified the float is working, the electro magnetic thing is getting 120 volts. I checked resistance on it and I'm getting .7 k ohms. I took the assembly apart and cleaned and I'm still not getting water. Does my water valve assembly seem to be my issue?
#2 Posted : Sunday, January 8, 2012 7:35:05 AM(UTC)
[COLOR="DarkRed"]Does my water valve assembly seem to be my issue?[/COLOR]
Since the vale is getting 120 volts and does not open, I would replace it.
Probably has an internal mechanical problem.
