Discuss
DW won't drain / fill
 in
Dishwasher Repair
Runs thru cycle "normal" except does not fill or drain (just uses water left in tub). Float free
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » DW won't drain / fill
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-02-2008, 05:02 PM
deertick deertick is offline
Junior Member
deertick is on a distinguished road
Exclamation DW won't drain / fill
Model Number: 587.14132102   Brand: Kenmore   Age: 1 - 5 years
Runs thru cycle "normal" except does not fill or drain (just uses water left in tub). Float free of obstructions and switch is heard while manually actuating. Hoses are clear. Motor / pump does not turn on to fill/drain, but does "wash". HELP!!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-02-2008, 06:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Assuming the water valve under the sink is open, I would start with the water inlet valve.
If water is coming to the dishwasher, check for 120V coming to the water inlet valve when the timer calls for water.
If there is 120V, then replace the water inlet valve.
If there is no 120V, then check wires. If there is nothing wrong - replace the timer.
- The part number for the water inlet valve is AP3790911
- The part number for the timer is AP3214619
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Does not fill complete scotto Dishwasher Repair 1 12-17-2007 12:10 PM
Washer will not fill roddude32 Washer Repair 3 12-11-2007 06:14 PM
Will fill, but it won't agitate, spin or drain ed0410 Washer Repair 5 12-11-2007 01:54 PM
IceMaker won't fill Snowman Refrigerator & Freezer Repair 1 12-02-2007 10:57 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
