In my previous post I mentioned that the lock on light and the heated dry light either blink continuously, or remain illuminated. The procedure to recover from this, according to the manual, is to hold the heated dry button for 4 seconds. This procedure did not work. So, today I removed the control panel from the machine, after killing power. I completely detached the control panel from the circuit board and set the panel aside. Nothing looks amiss. I reassembled all components. Upon initial ower up the heated dry light blinked for a few minutes. Then, for no apparent reason, the heated dry light extinguished and the machine operated normally. Upon completion of the wash cycle, the heated dry light is blinking again. Any ideas? Like a computer, does killing power reset the logic, or is there something else going on?
