| » dw motor won,t start |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: gu980scgb0 Brand: -brand- Age: 5 - 10 years
i just replace the motor & pump i turn it on the water fill up
then wait for the motor to on then heard a click waited to see it start nothing then i push cancel/ drain then motor started ran for 10 second then stop i replace because the other one was leaking & the motor burnt out it started to smoke |
You may have jammed something in the pump, just take apart and check. If ok, you may need to check your winding current per the schematic, could be a start relay/timer problem.
__________________
| Display Modes | |
| Gas dryer motor hums but won't start | nonqual | Dryer Repair | 5 | 12-27-2007 04:40 AM |
| whirlpool washer motor needs help to start | jes999 | Washer Repair | 3 | 12-16-2007 09:36 AM |
| Wont start/start switch replaced | awilliams197 | Dryer Repair | 1 | 09-18-2007 01:33 AM |
| Dryer motor is noisey and sometimes humms and doesn't start | Tudeman | Dryer Repair | 2 | 07-20-2007 03:20 PM |
