Discuss
dw motor won,t start
 in
Dishwasher Repair
i just replace the motor & pump i turn it on the water fill up then wait for the motor
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dw motor won,t start
  #1 (permalink)
Old 01-01-2008, 09:20 AM
tmenter1 tmenter1 is offline
Junior Member
tmenter1 is on a distinguished road
Default dw motor won,t start
Model Number: gu980scgb0   Brand: -brand-   Age: 5 - 10 years
then wait for the motor to on then heard a click waited to see it start
nothing then i push cancel/ drain then motor started ran for 10 second
then stop
i replace because the other one was leaking & the motor burnt out it started to smoke
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-01-2008, 01:56 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You may have jammed something in the pump, just take apart and check. If ok, you may need to check your winding current per the schematic, could be a start relay/timer problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 05:40 AM
whirlpool washer motor needs help to start jes999 Washer Repair 3 12-16-2007 10:36 AM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 02:33 AM
Dryer motor is noisey and sometimes humms and doesn't start Tudeman Dryer Repair 2 07-20-2007 04:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
