lizmc31
#1 Posted : Tuesday, December 27, 2011 10:06:43 AM(UTC)
lizmc31
suddenly tripped electricity and now when turned on tripps all the time no leaks so now turned off help
lizmc31
#2 Posted : Tuesday, December 27, 2011 10:35:39 AM(UTC)
lizmc31
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
greway
#3 Posted : Wednesday, January 4, 2012 9:24:45 AM(UTC)
greway
Had this happen to me a few years ago.
If hard wired, with cuircuit breaker off, remove kick plate and open wiring box to be sure not shorting out. Replace wire nuts and electrical tape wrap, make sure wire anchor is tight.
If using an outlet, try plugging into different circuit, in case outlet is bad.
