kendebj
#1 Posted : Friday, December 23, 2011 8:17:50 AM(UTC)
kendebj
door makes noise when opening and closing -- other than that it works fine
#2 Posted : Friday, December 23, 2011 3:12:28 PM(UTC)
Very likely the noise is caused by tension on the nylon cable from the spring, as it moves around the friction pulley.
Check the cables for any grease or oil, if the cables have been lubricated replace the cable and friction pulley it rides around. This may require replacing the cable and pulley on both sides. After checking or replacing these parts take a bar of regular unscented soap and liberally rub both of the cable and the door spring on both sides. Then open and close the door 4 or 5 times to work the soap into the cable and pulley to complete repair.
- The cable (2 needed) Part number: AP3958767
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
KDTE554CSS3 Dishwasher (Dishwasher Repair)
by olderwhite@yahoo.com 1/13/2024 10:34:56 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
