| » Check Valve for Kitchenaid Dishwasher |
Model Number: KUDSO1FLSS1 Brand: Kitchen Aid Age: 1 - 5 years
I am getting "coffee ground type residue" on the glassware in the top rack. I ordered a new chopper assembly but believe I need to replace the check valve as well. I am not sure where it is located however. I would appreciate it if someone could offer some assistance as to where it is located in the dishwasher and how to replace it.
thank you. Related Models |
When you are in replacing the chopper, just to the right in the sump is the check valve leading to the drain pump. Use some needle nose pliers and pull the old one out, and then just slip the new one in place.
Inspect your old chopper end, the white ends that engage the pump impeller. If it was worn badly, you must also replace the motor impeller. You will need to pull dw for this.
The check valve allows back flushing of the chopper screen at pump out periods.
__________________
- Last edited by richappy : 01-01-2008 at 12:51 PM. |
| Display Modes | |
| Need Check Valve for Part 560 Body Valve | mjt | Dishwasher Repair | 0 | 08-31-2009 07:08 AM |
| Replacing Check Valve and Piston Nut on Dishwasher | KentSmith | Dishwasher Repair | 2 | 04-01-2009 03:58 PM |
| whirlpool dishwasher check valve | herdfan03 | Dishwasher Repair | 1 | 12-03-2008 01:45 AM |
| Kenmore Dishwasher Drain Check Valve | gdaarob | Dishwasher Repair | 2 | 11-20-2008 02:49 PM |
| Kitchenaid dishwasher check valve question | solarisdude7@yahoo.com | Dishwasher Repair | 0 | 09-29-2008 10:39 AM |
