Discuss
Check Valve for Kitchenaid Dishwasher
 in
Dishwasher Repair
I am getting "coffee ground type residue" on the glassware in the top rack. I ordered a new
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Check Valve for Kitchenaid Dishwasher
  #1 (permalink)
Old 12-31-2007, 12:17 PM
mark.sapienza@acco.com mark.sapienza@acco.com is offline
Junior Member
mark.sapienza@acco.com is on a distinguished road
Default Check Valve for Kitchenaid Dishwasher
Model Number: KUDSO1FLSS1   Brand: Kitchen Aid   Age: 1 - 5 years
I am getting "coffee ground type residue" on the glassware in the top rack. I ordered a new chopper assembly but believe I need to replace the check valve as well. I am not sure where it is located however. I would appreciate it if someone could offer some assistance as to where it is located in the dishwasher and how to replace it.
thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 04:11 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
When you are in replacing the chopper, just to the right in the sump is the check valve leading to the drain pump. Use some needle nose pliers and pull the old one out, and then just slip the new one in place.
__________________
TechnicianBrian
Appliance Repair Blog
  #3 (permalink)
Old 01-01-2008, 11:12 AM
Junior Member
Default
Thank you for the quick response. I should be able to locate it now. I was afraid it was only accessible from underneath the unit.
Happy new year.
  #4 (permalink)
Old 01-01-2008, 01:49 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Inspect your old chopper end, the white ends that engage the pump impeller. If it was worn badly, you must also replace the motor impeller. You will need to pull dw for this.
The check valve allows back flushing of the chopper screen at pump out periods.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to Check Washer Motor & Capacitor mickey11 Washer Repair 2 06-15-2008 10:09 AM
To check defrost heater don419 Refrigerator & Freezer Repair 2 02-26-2008 09:51 PM
flapper check valve & beading for spray arm low laineyo Dishwasher Repair 1 11-25-2007 08:21 AM
how to check thermo fuse and thermostat lilphil Dryer Repair 0 11-20-2007 08:43 AM
How can I check the relay and/or cap frepair Refrigerator & Freezer Repair 1 10-18-2007 08:37 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
