Discuss
Dishwasher unresponsive
 in
Dishwasher Repair
Hello all, I am hoping I may get some direction on how to proceed. I have a Bosch SMU4056; and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher unresponsive
  #1 (permalink)
Old 06-30-2009, 11:52 AM
Randog Randog is offline
Junior Member
Randog is on a distinguished road
Default Dishwasher unresponsive
Model Number: SMU4056   Brand: Bosch   Age: More than 10 years
Hello all,
I have a Bosch SMU4056; and until recently, it has been a great performer.
The washer was working great and then one day it just stopped in the middle of the wash cycle.
If I cycle through the different cycles it does nothing. There is no sound, no pump noise. Nothing.
I used a shopvac to get the water out of the unit.
I am not sure how to proceed to troubleshoot the unit. I have not been able to find much of anything on the internet for test procedures.
Any direction and help woul dbe greatly appreciated.
Thank you in advance,
Randy
Related Models
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
Maytag SMV9165BC Mwave - Mounted Over Range/wo
Maytag SMV9165CC Mwave - Mounted Over Range/wo
Maytag SMV9165SC Mwave - Mounted Over Range/wo
Maytag SMV9165WC Mwave - Mounted Over Range/wo
Thermador SMW272B
Thermador SMW272P
Thermador SMW272S
Thermador SMW272W
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Whirlpool SN
Amana SNAC-700.A Commercial Microwaves
Amana SNAC-700.B Commercial Microwaves
Amana SNAC-7TP.A Commercial Microwaves
Amana SNAC-7TP.B Commercial Microwaves
Amana SNAC700 Commercial Microwaves
Amana SNAC700.C Commercial Microwaves
Amana SNAC700.D Commercial Microwaves
Amana SNAC7TP.003 Commercial Microwaves
Amana SNAC7TP.004 Commercial Microwaves
Amana SNAC7TP.005 Commercial Microwaves
Amana SNAC8LW Commercial Microwaves
Amana SNE26AA Range - Electric Std Delaware
Amana SNE26CB Range - S/c S/i Ddraft Gas
Amana SNE26ZZ Range - S/c S/i Ddraft Gas
Whirlpool SNFGA
Amana SNK26AA Range - S/c S/i Ddraft Gas
Amana SNK26AA0 Range - S/i Std Gas
Amana SNK26AA5 Range - S/i Std Gas
Amana SNK26CB Range - S/c S/i Ddraft Gas
Amana SNK26CB0 Range - S/i Std Gas
Amana SNK26CB5 Range - S/i Std Gas
Amana SNK26FS Range - S/c S/i Ddraft Gas
Amana SNK26FS0 Range - S/i Std Gas
Amana SNK26FS5 Range - S/i Std Gas
Amana SNP26AA Range - S/i Std Gas
Amana SNP26AA0 Range - S/i Std Gas
Amana SNP26AA5 Range - S/i Std Gas
Amana SNP26AH0 Range - S/i Std Gas
Amana SNP26CB Range - S/i Std Gas
Amana SNP26CB0 Range - S/i Std Gas
Amana SNP26CB5 Range - S/i Std Gas
Amana SNP26ZZ Range - S/i Std Gas
Amana SNP26ZZ0 Range - S/i Std Gas
Whirlpool SNPA
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A Ref - SXS/I&W
Amana SP17A-A Ref - SXS/I&W
Amana SP17A-AG Ref - SXS/I&W
Amana SP17A-C Ref - SXS/I&W
Amana SP17G Ref - SXS/I&W
  #2 (permalink)
Old 06-30-2009, 07:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Randy,
The first thing I would do is check for 120 VAC to the dishwasher.
Remove the toe panel and check the power cord connection to the dishwasher for burned wires and/or lose connections.
Remove the outer door panel and check all wires inside the door.
Check the "on-off" and the door switches.
Here are the breakdown diagrams and Replacement parts for BOSCH SMU4056 UC/09 (FD 7307-7902) | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 06-30-2009, 08:00 PM
Junior Member
Default
I will verify the voltage when I get home tonight. I had the thing apart last night but had no clue where to check, and what to check.
I'll start with the voltage and wires.
Thank you for your help!
  #4 (permalink)
Old 06-30-2009, 08:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #5 (permalink)
Old 06-30-2009, 11:26 PM
Junior Member
Default
I checked the incoming line and the power coming is 110v; so that is good.
I checked the voltage at the lines coming in to the Selector Switch Assembly and the voltage is still good. From there, I am not too sure what voltages should be - and where.
The odd thing, and I don't know if this is norl - I cannot remember - is that then the door is opened and the on/off switch is depressed the light comes on (for behind the on/off switch) but once the door is closed - the light goes out. Very odd.
I noticed that the motor for the timer unit is not turning. From what I can gather it is not getting power (?)
I did not get a chance to yank the unit out from under the counter top. That will be tomorrow.
The I guess I can check the other components.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Locked but unresponsive Maytag dgmsam Dishwasher Repair 1 02-21-2009 07:05 AM
