Discuss
Upper 'Arm' Dead in KenElite (NOT the Chopper!)
 in
Dishwasher Repair
Been living with this for a while....glas.ses never get really clean, oftentimes there's detergent & crud on the upper part
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Upper 'Arm' Dead in KenElite (NOT the Chopper!)
  #1 (permalink)
Old 12-17-2011, 09:26 PM
Junior Member
deandome is on a distinguished road
Default Upper 'Arm' Dead in KenElite (NOT the Chopper!)
Model Number: Basic Whirlpool w/the chopper that always fails   Brand: Kenmore   Age: 1 - 5 years
Been living with this for a while....glas.ses never get really clean, oftentimes there's detergent & crud on the upper part of the door... but lower rack stuff is fine. I can tell the upper 'arm' (little plastic 'yin-yang symbol' shaped) isn't spinning at all.
I've already checked the chopper, it's fine (replaced it about 1.5 years ago), as is the rubber 'check valve' thingie that's next to the chopper. We're good about pushing the upper rack all the way in, so it engages one of the two holes. I've checked the plastic 'pipe w/the upper arm...there's no detergent or other gunk clogging things up
I just can't figure what the problem might be! Part of me thinks it's the pump...something blocking something inside it, past the chopper...but I can't figure how it would be working at, say, half-strength; I'd think it would be all good, or dead.
Is there somewhere besides the chopper where gunk/stuff clogs something up & reduces the flow/pressure?
Related Models
Amana BB20V1E REF - BOTTOM MOUNTS
Amana BB20V1PS REF - BOTTOM MOUNTS
Amana BB20V1S REF - BOTTOM MOUNTS
Amana BB20V1W REF - BOTTOM MOUNTS
Amana BB20VE REF - BOTTOM MOUNTS
Amana BB20VPSE REF - BOTTOM MOUNTS
Amana BB20VSE REF - BOTTOM MOUNTS
Amana BB20VW REF - BOTTOM MOUNTS
Frigidaire BBBD2432KB0 DISHWASHER
Frigidaire BBBD2432KF0 DISHWASHER
Frigidaire BBBD2432KW0 DISHWASHER
Amana BBI20TE REF - BOTTOM MOUNTS
Amana BBI20TL REF - BOTTOM MOUNTS
Amana BBI20TPE REF - BOTTOM MOUNTS
Amana BBI20TPL REF - BOTTOM MOUNTS
Amana BBI20TPSW REF - BOTTOM MOUNTS
Amana BBI20TPW REF - BOTTOM MOUNTS
Amana BBI20TW REF - BOTTOM MOUNTS
Amana BC20B REF - BOTTOM MOUNTS
Amana BC20BA REF - BOTTOM MOUNTS
Amana BC20BC REF - BOTTOM MOUNTS
Amana BC20BG REF - BOTTOM MOUNTS
Amana BC20BL REF - BOTTOM MOUNTS
Amana BC20C REF - BOTTOM MOUNTS
Amana BC20CA REF - BOTTOM MOUNTS
Amana BC20CC REF - BOTTOM MOUNTS
Amana BC20CG REF - BOTTOM MOUNTS
Amana BC20CL REF - BOTTOM MOUNTS
Amana BC20D REF - BOTTOM MOUNTS
Amana BC20DA REF - BOTTOM MOUNTS
Amana BC20DC REF - BOTTOM MOUNTS
Amana BC20DG REF - BOTTOM MOUNTS
Amana BC20DL REF - BOTTOM MOUNTS
Amana BC20E REF - BOTTOM MOUNTS
Amana BC20EA REF - BOTTOM MOUNTS
Amana BC20EC REF - BOTTOM MOUNTS
Amana BC20EG REF - BOTTOM MOUNTS
Amana BC20EL REF - BOTTOM MOUNTS
Amana BC20H REF - BOTTOM MOUNTS
Amana BC20J REF - BOTTOM MOUNTS
Amana BC20K REF - BOTTOM MOUNTS
Amana BC20M REF - BOTTOM MOUNTS
Amana BC20N REF - BOTTOM MOUNTS
Amana BC20TL REF - BOTTOM MOUNTS
Amana BC20TW REF - BOTTOM MOUNTS
Amana BC20W REF - BOTTOM MOUNTS
Amana BC20WA REF - BOTTOM MOUNTS
Amana BC20WAG REF - BOTTOM MOUNTS
Amana BC20WC REF - BOTTOM MOUNTS
Amana BC21V1C REF - BOTTOM MOUNTS
Amana BC21V1W REF - BOTTOM MOUNTS
Amana BC21VC REF - BOTTOM MOUNTS
Amana BC21VL REF - BOTTOM MOUNTS
Amana BC21VW REF - BOTTOM MOUNTS
Frigidaire BCEQ2152ES0 Frigidaire Canada/electric Dryer
Frigidaire BCEQ2152ES1 FRIGIDAIRE
Frigidaire BCEQ6100FS0 Frigidaire/dryer
Frigidaire BCEQ6700FS0 FRIGIDAIRE/DRYER
Amana BCI20B REF - BOTTOM MOUNTS
Amana BCI20BA REF - BOTTOM MOUNTS
Amana BCI20BC REF - BOTTOM MOUNTS
Amana BCI20BG REF - BOTTOM MOUNTS
Amana BCI20BL REF - BOTTOM MOUNTS
Amana BCI20C REF - BOTTOM MOUNTS
Amana BCI20CA REF - BOTTOM MOUNTS
Amana BCI20CC REF - BOTTOM MOUNTS
Amana BCI20CG REF - BOTTOM MOUNTS
Amana BCI20CL REF - BOTTOM MOUNTS
Amana BCI20D REF - BOTTOM MOUNTS
Amana BCI20DA REF - BOTTOM MOUNTS
Amana BCI20DC REF - BOTTOM MOUNTS
Amana BCI20DG REF - BOTTOM MOUNTS
Amana BCI20DL REF - BOTTOM MOUNTS
Amana BCI20E REF - BOTTOM MOUNTS
Amana BCI20EA REF - BOTTOM MOUNTS
Amana BCI20EC REF - BOTTOM MOUNTS
  #2 (permalink)
Old 12-18-2011, 06:42 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may hep others help you.
Any filter in the unit that is partially clogged will cause low water pressure,
Check that the holes in the upper arm are clear of debris.
Often low pressure is due to a low fill.
Most units should fill to just under the heating element.
To check this add a couple quarts of hot water just after a fill.
Just be careful to not overfill the unit.
Now if the arm spins OK then low fill is probably your cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upper 'Arm' Dead in KenElite (NOT the Chopper!) deandome Dishwasher Repair 1 12-18-2011 06:56 AM
Dishwasher Chopper lkost Dishwasher Repair 4 09-08-2011 03:40 PM
Chopper Engaging davilafam50 Dishwasher Repair 7 08-04-2010 02:38 PM
chopper-impeller kit bushrat Dishwasher Repair 1 04-19-2010 07:09 PM
chopper assembly isadora Dishwasher Repair 1 11-28-2008 05:25 AM
