Discuss
No Power
 in
Dishwasher Repair
My Kenmore dishwasher has no power. An electrician checked the breaker and the connections and there is power to the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No Power
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-29-2007, 01:43 PM
ppiazzola ppiazzola is offline
Junior Member
ppiazzola is on a distinguished road
Default No Power
Brand: Kenmore   Age: 1 - 5 years
My Kenmore dishwasher has no power. An electrician checked the breaker and the connections and there is power to the Electronic Control Assembly. The Electronic Control Assembly was replaced and still no power. The dishwasher was working great before the loss of power. Ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-29-2007, 02:41 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Need model # to help. Look for a thermal fuse that plugs into the electronic module, probably blown.It is a white sort of square thing.
__________________
  #3 (permalink)
Old 01-02-2008, 09:50 AM
rjs wf tx rjs wf tx is offline
Junior Member
rjs wf tx is on a distinguished road
Default whirlpool dw same issue
Quote:
I had the same problem with my Whirlpool dishwasher model: DU1100XTPB7. Replaced the thermal fuse and it fixed the problem; however, one month later I'm having the same problem...no power. I suspect the fuse is not the problem because it's doing what it is supposed to do. The question is why is it blowing...why is circuit overheating?
Thanks,
Randy
  #4 (permalink)
Old 01-02-2008, 12:18 PM
Senior Expert
APP Volunteer
Default
I suspect a power surge blew the fuse.Or it could be a timing error from the electronic module. You might want to confirm by checking the current draw at different periods of the wash/drain/heating cycle. If ok you might want to wire in a surge protector.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Power kimmer Dishwasher Repair 7 01-19-2008 06:13 PM
No Power jemperly Dishwasher Repair 1 12-26-2007 02:42 PM
No Power SteveM Microwave Repair 1 12-05-2007 05:44 PM
No Power. dogfuzzn Washer Repair 2 10-11-2007 03:52 AM
No Power? dangdryer Dryer Repair 0 09-05-2007 04:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
