Discuss
dishwasher
 in
Dishwasher Repair
I have a Maytag dishwasher. model # MDB7650AWW. Tried to use dishwasher this morning I hit the start button. It
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher
  #1 (permalink)
Old 12-13-2011, 08:06 AM
Junior Member
allenwva is on a distinguished road
Default dishwasher
Brand: Maytag   Age: 5 - 10 years
I have a Maytag dishwasher. model # MDB7650AWW. Tried to use dishwasher this morning I hit the start button. It started a put some water in. It then buzzed (sounded like it came from the top) and then turned itself off. Opened up the door there is water standing in the bottom. tried to restart. would not start, just makes a buzzing sound 4 times and then turns off. can you tell me what the problem might be?
  #2 (permalink)
Old 12-13-2011, 08:16 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The first thing I would check is the power connection under the machine. Look to see if one of the wire connections came loose. Especially look for a loose ground or neutral.
  #3 (permalink)
Old 12-13-2011, 08:18 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Could be a bad motor tripping out on the build in overload or something stuck inside it that is keeping the motor from turning.
I would also remove the access panel at the bottom of the dishwasher and look around under it, does it look like it's been seeping any water on the motor or connections?
Here is the service manual for your model dishwasher, you may find it helpful.
http://appliancejunk.com/forums/inde...a=view;down=83
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher control lights out and dishwasher stopped working hatchchuck Dishwasher Repair 1 12-26-2010 04:48 AM
Dishwasher will not empty no lights on front of dishwasher except led lines badtothebone Dishwasher Repair 0 05-13-2010 02:17 PM
Dishwasher will not empty no lights on front of dishwasher except led lines badtothebone Dishwasher Repair 0 05-13-2010 02:14 PM
dishwasher spray arm melted to heating element and now dishwasher not working msphillips2 Dishwasher Repair 0 05-08-2010 10:21 AM
