Discuss
will not pump
 in
Dishwasher Repair
The Diswasher Will Not Pump Out The Water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » will not pump
  #1 (permalink)
Old 12-27-2007, 03:28 PM
tribble121 tribble121 is offline
Junior Member
tribble121 is on a distinguished road
Default will not pump
Brand: Whirlpool   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 05:30 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
first of all remove dishwasher drain hose from under sink counter. push screw driver into drain nipple to unblock , look into hose end to see if its clear .put hose back on +try cancel drain again +see what happens. if it does not drain remove kick plate , remove hose from drain check valve attached to motor on right side .un thread drain check valve .+remove check for crap inside ,reinstall valve tighten snuggly .do not over tighten,replace hose ,try again
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
pump out but no spin ericand Washer Repair 2 12-05-2007 03:20 AM
water pump ? CAT88 Washer Repair 0 10-27-2007 12:24 PM
Is it the Washer Pump aorose Washer Repair 1 10-27-2007 11:01 AM
water pump going bad CAT88 Washer Repair 1 10-23-2007 05:42 PM
Changing Pump pdiddy Washer Repair 1 07-20-2007 07:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
