| » will not pump |
first of all remove dishwasher drain hose from under sink counter. push screw driver into drain nipple to unblock , look into hose end to see if its clear .put hose back on +try cancel drain again +see what happens. if it does not drain remove kick plate , remove hose from drain check valve attached to motor on right side .un thread drain check valve .+remove check for crap inside ,reinstall valve tighten snuggly .do not over tighten,replace hose ,try again
__________________
| Display Modes | |
| pump out but no spin | ericand | Washer Repair | 2 | 12-05-2007 03:20 AM |
| water pump ? | CAT88 | Washer Repair | 0 | 10-27-2007 12:24 PM |
| Is it the Washer Pump | aorose | Washer Repair | 1 | 10-27-2007 11:01 AM |
| water pump going bad | CAT88 | Washer Repair | 1 | 10-23-2007 05:42 PM |
| Changing Pump | pdiddy | Washer Repair | 1 | 07-20-2007 07:05 PM |
