country girl
#1 Posted : Saturday, June 20, 2009 2:05:26 PM(UTC)
country girl
Two weeks ago the water inlet got stuck open and dumped water all over the kitchen floor. Replaced that and it worked fine for a week. It quit mid cycle. It still has some water in the tub. None of the lights work on the front panel touch pad. There is power throughout the control panel, and the fuse has power through it. What would be the next thing to check. Is there a way to test the front panel touch pad to see if that is what's bad? I'm tired of spending money on parts that don't fix the problem. :(
#2 Posted : Saturday, June 20, 2009 5:00:58 PM(UTC)
Perform the troubleshooting as described in the tech sheets.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDM01TJBS0 | AppliancePartsPros.com
Frigidaire FFMV154CLSA microwave replaced door latch now won't run (Microwave Repair)
by jigeye 8/23/2022 4:05:37 PM(UTC)
Whirlpool GR5620KQ1 Buzzes won't run (Dryer Repair)
by Fran_Ko 3/17/2022 12:56:48 PM(UTC)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Whirpool Duet Sport won't run Diagnostic Test (Washer Repair)
by RIPPTA 11/19/2019 1:28:05 PM(UTC)
whirlpool front load won't run door locked won't open. (Washer Repair)
by bob67 12/6/2018 3:54:59 PM(UTC)
Maytag Washer LAT9334AAE motor won't run (Washer Repair)
by katikelcykiley 10/30/2018 5:43:28 AM(UTC)
Dishwasher fills and drains but won't run (Dishwasher Repair)
by LiquidPony 3/5/2018 1:29:23 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Kenmore washer won't fill won't run motor trips (Washer Repair)
by MEE1963 9/16/2017 10:53:07 AM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
ge microwave fans won't run (Microwave Repair)
by bvectra 2/20/2017 5:55:41 AM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Maytag Elite Dryer - Won't Run, Not the Fuses (Dryer Repair)
by BhamBigDaddyD 10/14/2016 9:45:56 AM(UTC)
Maytag Centennial won't run - need help with error code (Washer Repair)
by Pepps 8/9/2016 2:21:04 PM(UTC)
