| » Washer drum won't turn |
Model Number: MAH5500BWW Brand: Maytag Age: 5 - 10 years
Washer quit working today during a wash load. The washer sounds like it is draining. this sound does not stop until you push the stop button. I unplugged the machine and tried restarting. The washer begins to fill but the drum wil not turn. Tried restarting with the spin option. Washer drained but drum not turning. Took the back panel off the machine. The belt is on the pulley and turns freely. Any ideas? Thanks
See if you can find the tech sheet in the top control panel. Try and run it through diagnostics using the tech sheet. Could be a bad motor control board.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| Washer drum want turn | jimmie_lou | Washer Repair | 1 | 11-02-2011 07:12 PM |
| New belt, but squeaks and sometimes doesn't turn washer drum | jesus freak | Washer Repair | 1 | 03-31-2011 02:01 PM |
| Frigidaire front loading washer, drum will not turn. | kwalityguru | Washer Repair | 1 | 09-10-2009 04:08 PM |
| Drum will not turn | David Rivera | Dryer Repair | 1 | 07-11-2008 01:03 PM |
| Admiral Designer Series washer - spins some during agitation; can turn drum while off | John Z | Washer Repair | 1 | 07-03-2008 08:13 PM |
