Discuss
Upper level does not get washed - sandy residue on glasses, etc
 in
Dishwasher Repair
Problem is getting worse - we tried running empty w/vinegar, running hot water at tap before starting, using pots &
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Upper level does not get washed - sandy residue on glasses, etc
  #1 (permalink)
Old 12-27-2007, 10:00 AM
JayeLesley JayeLesley is offline
Junior Member
JayeLesley is on a distinguished road
Default Upper level does not get washed - sandy residue on glasses, etc
Model Number: 363.1434595   Brand: Kenmore   Age: More than 10 years
Problem is getting worse - we tried running empty w/vinegar, running hot water at tap before starting, using pots & pans cycle - nothing helped. There does not seem to be a blockage anywhere but anything on the top level remains dirty and splattered with sandy residue. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 11:36 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the water level inside the dishwasher.
Normally it suppose to be about 1/2" above the floor in the middle of the dishwasher (around the spray arm support).
If there is not enough water, then the water inlet valve has to be replaced.
If there is nothing wrong, check the pop up tower (center spray arm) for any damages.
- The part number for the water inlet valve is AP2039339
- The part number for the center spray arm is AP2039812
The center spray arm
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Grit in glasses on top shelf caramb Dishwasher Repair 2 04-01-2008 12:11 PM
water level Jerome Pikus Washer Repair 1 12-16-2007 03:29 PM
second level sprayer denpet Dishwasher Repair 0 10-25-2007 11:24 AM
Maytag Washer Inlet valve - water level switch reisman Washer Repair 0 10-23-2007 09:36 PM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 04:34 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
