Discuss
Bosch dishwasher rattle, low wash pressure
 in
Dishwasher Repair
Our dishwasher makes a rattling noise, and does not wash properly. The soap doesn't even get fully dissolved. The noise
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher rattle, low wash pressure
  #1 (permalink)
Old 06-18-2009, 10:13 AM
Junior Member
billyderbes is on a distinguished road
Default Bosch dishwasher rattle, low wash pressure
Model Number: SHU43C02UC   Brand: Bosch   Age: 5 - 10 years
Our dishwasher makes a rattling noise, and does not wash properly. The soap doesn't even get fully dissolved. The noise is associated with rotation - it winds down when I power off.
Ads By Google
Related Models
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
  #2 (permalink)
Old 06-18-2009, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove all filters and screens inside the dishwasher and clean them. Check for a broken glass inside. If it would not help then you have to pull the dishwasher out of the cabinet, remove the circulation pump and check it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-18-2009, 09:40 PM
Junior Member
Default
Thanks. Do you know where I can get a repair manual or procedure so I can get at that pump? If I even knew where it was, I might be able to reach it from the toekick to be sure that's where the noise is coming from.
  #4 (permalink)
Old 06-18-2009, 10:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The instruction is attached to the reply.
File Type: doc How to remove the base from the tank.doc (549.5 KB, 115 views)
File Type: doc How to remove the circulation pump.doc (634.5 KB, 125 views)
__________________
  #5 (permalink)
Old 06-27-2009, 10:21 PM
Junior Member
Default two piece impeller - supposed to be separate?
I got the pump off and found a two piece impeller. Several pegs in the face of one disc engage several holes in the other, but they come apart easily. Is that normal? If so, it seems I should be able to just put them back together. I tried that, but ran into another problem. The pump won't go back in the housing. There are 4 sliding tabs, but no stagger or lead-in. Looks like I have to remove the pump housing to to get all 4 tabs engaged at once. Any instruction on how to do that?
  #6 (permalink)
Old 09-09-2009, 06:13 AM
Junior Member
hunterdog is on a distinguished road
Default
Do the instructions you provided for the circulator pump also apply to the Bosch shu9925uc/12?
  #7 (permalink)
Old 09-09-2009, 04:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Yes. it should be good for your dishwasher as well.
Here are the breakdown diagrams for the Bosch dishwasher Model SHU9925 UC/12
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher long wash period richappy Dishwasher Repair 1 04-06-2012 11:05 AM
Bosch dishwasher wil not wash help!!! rpatters Dishwasher Repair 8 07-28-2011 01:26 PM
Bosch Dishwasher hangs at Wash cycle JBM Dishwasher Repair 11 05-31-2010 09:57 PM
Bosch dishwasher won't move from wash to rinse howleyj Dishwasher Repair 0 10-03-2009 07:59 AM
Bosch Dishwasher Will only work on scrub wash cycle. jplmruss Dishwasher Repair 3 06-16-2008 09:05 PM
